Lighting the kerosene oven?
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
I have a Kenyon(?) 3-burner kerosene stove with oven in my Ontario 32. It's kinda growing on me - I don't mind the pre-heating and once it's going, it works really well with no noticeable smell. BUT - there's an oven, and I can't figure out how to use it.
Can someone tell me how to use the oven: where to put the preheat alcohol, what to light, how to regulate the heat...
druid
"Wind Drift"
Jan 2, 2009
93
Gulfstar 50 ketch holland
The same as stove top to light and adjust. Except the oven should have a plate in the bottom over the burner you have to lift to light. Get a thermometer to check and adjust temp, hangs on rack type.
Mar 1, 2012
2,182
A hint-
I've used kerosene stoves on all my boats since 1976, and I've used 100% mineral spirits as a fuel for that entire time. Burns cleaner than the kerosene available these days, and doesn't cost any more.
No difference in lighting either, and you'll find you don't need to clean the orifice as often.
druid
Apr 22, 2009
837
Druid
If you are looking for a manual for your stove, this may be quite close: http://cdn.shopify.com/s/files/1/0152/2433/t/2/assets/alc-stove-550-555-manual.pdf
There are more manuals on this site: http://www.cookwithkenyon.com/pages/parts-list-manuals
Matt
OK this is close (except that is for an alcohol stove, and 2-burner rather than 3). I think my problem lies in the phrase "... the baffles must be raised to prime the burner". I can see the burner under the plate, but I can't see how to get at it to prime it. Any suggestions?
druid
"Wind Drift" Ontario 32
Mar 1, 2012
2,182
I use a small plastic squeeze bottle with a flip open spout, and put the alcohol (denatured or red label rubbing) on top of the burner- it'll run down into the priming cup quite nicely. Just be sure to not squirt too much. Start with a bit too little, and after a time or two you'll know how much.
Pretty easy really.
Red label rubbing alcohol is 91 %. The 70% will work also, but lesser ones don't burn well.
