I didn't mean to star a pissin match. I just wondered if the mast was grounded between the shells. I'm not worried about being in it, just don't want to find my Mac sitting on the bottom because it's the highest pont.
Ok, (pls critique this plan).
Copper pipe attached (bolted to the mast, and at least 4 gauge wire (copper) attached to the pipe, at the end of the wire, a length of copper pipe, that is on the surface with foam (noodles).
-copper wire is going to corrode pretty quick (green film) in salt, so more resistance,(more ohms), so, go up up a wire size or two? (any alternative to the copper wire? )
in fla, summer storms are normal with lighting. if you're on the water its only a matter of time till you get into it...
I wouldn't mind having this kind of setup is a bag -in case. (or at the dock).
Sum, that some medieval looking device...
where did you get that? Did I miss walt is selling this device?
We were field testing it for him on our fall of 2011 and spring 2012 Florida trip. We left it in the water the entire time to see the effects of the salt water on the electrode body, the electrodes themselves, the foam and the connectors. Everything held up very well and when we got back we returned them to him so that he could cut them apart and measure resistance and such....Sum, that some medieval looking device...
...Sum, (I assume) the key to this is the mast to wire connection. how did the wire look (greenish) at the end? ....
I'm starting to think that we might not get the boat (the Endeavour) out this trip and if we do it would just be in Charlotte Harbor most likely. We worked so many 10 hour days before leaving and then the 4 day trip down here kicked our butt, plus we left there in snow and got here to 80+ temps. The first 1 1/2 weeks were a bust getting anything done......and Sum, you may get to test this thing if you stick around long enough!
planning on heading south to the keys, or over to biscayne bay?..
Sorry, that's the last thing I wanted to do. You guys are discussing something near and dear to me and I find it very interesting. I was hoping that I was adding something to your conversation. I am especially peaked by the floating electrode. I would like to read more about it, but like any system, the problem and big trade-off isn't so much how effective the floating electrode is, but the method of routing the surge to that electrode. Large surges, like those from a direct lightning strike, will not readily change direction and route along a wire across the deck all that well. Like others have pointed out though, some is better than none and the trade-offs on a water ballasted boat are more than those with a traditional keel.I didn't mean to star a pissin match. I just wondered if the mast was grounded between the shells. I'm not worried about being in it, just don't want to find my Mac sitting on the bottom because it's the highest pont.
Yep there are some trade-offs with the system. I've talked a little to Walt about the transition from...... I am especially peaked by the floating electrode. I would like to read more about it, but like any system, the problem and big trade-off isn't so much how effective the floating electrode is, but the method of routing the surge to that electrode. Large surges, like those from a direct lightning strike, will not readily change direction and route along a wire across the deck all that well. Like others have pointed out though, some is better than none and the trade-offs on a water ballasted boat are more than those with a traditional keel.
I guess that would work... but your mast is still connected so there is a risk of jumps from the shrouds?Yes in a sense. I was under the impression that the collector as you call it had to be above the mast. I am using a heavy cable on the outside at the base that goes to a plate in the water.
I don't think it's a good idea to mount copper directly to the mast - your inviting corrosion issues... Copper and aluminum?Hollyweirdos said:Ok just picked up my new homemade air antenna. I would like your feedback on to best mount it. I may have to relocate the windex. It is 1/2" copper pipe with an adapter to 1 1/2" for the bulb. At the bottom, I am using #2 cable attached to am aluminum plate. The shrouds have their own cables and aluminum pieces. Haven't bonded the parts inside. Not sure how to best do it.
