Lift Raft??
Apr 10, 2010
132
Catalina 310 166 Dartmouth, Nova Scotia
Regarding an insulated floor, liferafts do not have
them. There is a manual pump onboard the raft and that is used to pump up the floor to provide insulation from the water. They work well. The inflation bottle is used exclusively to inflate the main buoyancy chambers.
Likes: GeneraiT001
Sep 8, 2025
126
Bayfield 36 Lewisporte
Thoughts on Rafts. Don't carry it below on passage. I know two boats that snagged the painter trying to get it up the companionway. The raft inflated below decks. Fortunately they are rescued quickly.
Second I know a boat that had the raft in front of the dodger. They could not get to it because lying a hull the deck was being swept by waves. The raft needs to be adjacent to the cockpit.
Thanks Stuart. Inflating below decks would be a nightmare :(
colemj
Jul 13, 2004
1,036
Liferafts have a 12 meter long painter with all but the first 10" stowed inside their container/valise, and it takes a sharp tug on that painter when fully extended to trigger the gas bottle. They are intentionally designed to prevent accidental inflation. Getting one to activate below decks would be quite the feat.
All but the cheapest coastal rafts have insulated floors. There are only a couple of brands/models that use inflatable floors.
Mark
Likes: GeneraiT001
JBP-PA
Apr 29, 2022
782
Jeanneau Tonic 23 Erie, PA
Hello,
I am interested in this because I am thinking of doing an off shore race (Annapolis to Newport) and the rules require a raft. My boat has a life raft storage area in the cockpit. A 6 person off shore raft from Superior Life-Saving seems to be a good choice and (relatively) affordable at around $2200.
The US Safety Equipment Requirements for OCEAN states
A boat shall carry adequate inflatable life raft(s) designed for saving life at sea with designed capacity for containing the entire crew. The raft shall be certified by the manufacturer or manufacturer-authorized inspection certificate as compliant with ISO 9650-1, or SOLAS, or ISAF (if made before 2016), or ORC (if made before January 1, 2004). Each raft shall be stored in such a way that it is capable of being launched within 15 seconds. Boats built after 01/06/2001 shall stow each life raft a deck-mounted rigid container in watertight or selfdraining purpose-built rigid compartment(s) opening adjacent to the cockpit or the working deck. Boats built prior to 01/06/2001 may alternatively stow each life raft in a valise not weighing over 88 lbs. securely below deck and adjacent to the companionway. Life raft(s) shall hold current manufacturer-authorized certificate(s) of inspection
landfall navigation and defender carry many different rafts.
Good Luck,
Barry
If you have a one time need or will rarely do passages, you can rent life rafts. Here is one link, but there are others.
Nov 20, 2025
28
Alden 60' Schooner Killybegs
I have circumnavigated about 7 times or so as a cruiser, depending on how you measure it plus twice crewing on racing boats. I carried a life raft for about half of that sailing and I've run into cruisers with every attitude imaginable about them. I'm not for or against. Like anything, if you have the space and budget, you're better off with than without.
That's true of just about anything you might carry though. The problem I see with life rafts is that people place too much faith in that single point of failure and they are too quick to use it when it isn't the best option available to them. And, they carry them at the cost of not carrying other important supplies and equipment. It almost seems like they figure, "I paid good money for this raft and, by God, I'm going to get my money's worth."
My attitude about them is simple. It is the very last piece of equipment I will need on my boat. It comes behind a long list of items that I will want or need BEFORE needing that raft. If, after all of that gear I still have room for the raft, I will carry it. Why not? I would be foolish to be standing on the deck of my sinking boat staring at the empty spot I could have secured the life raft. That would be a fitting end for me but I would rather not be my own punchline.
Unless space and budget are both in surplus, you are better off focusing on repair. Boats don't usually sink off-shore. They sink when they encounter land or sea monsters and the life raft won't do you much good in either case. People abandon boats because they can't fix them and they somehow figure they'll have better odds in the raft, which is rarely the case.
Fire that you can't extinguish or leaking you can't stop - those are about the only good reasons to get in a life raft and those events are rare off-shore. They do happen and, if they do, you're better off with a raft than without one. But, if I had to choose between a life raft and extra fuel or between a life raft and taking a rigging course or between a life raft and just about anything - well, a life raft just isn't likely to save the life of my crew and I can think of a long list of things that are more likely.
We picked up a couple in a life raft a few hundred miles from Hawai'i and came across their boat adrift the next day. We fixed their motor in about 2 hours because we had the skills, parts, and tools they lacked. By the way, it was just a bad fuel filter initially but then the ran their batteries down trying to start it so lost their VHF and SSB. Weather was fair throughout the whole incident.
They beat us to Honolulu and bought us dinner when we arrived. If that was an isolated incident, I might have a different attitude, but the proof is in the pudding. Sure there are cases where a crew abandons a vessel that is no longer seaworthy, and are later rescued. That happens. But it is so rare that it hardly bears strong consideration.
