Upgrading lifelines
There are two major considerations for fitting new lifelines. The first is the wire. Prior wisdom specified that horrid white coating over SS 7x7 (steering and halyard) cable. The first issue is that 7x7 cable, being what it is, has many more crevices to collect moisture, which seems to ooze its way down the cable from the ends and lurk under under the 'protective' plastic coating till it can corrode away as much of the cable as it can. This weakens the cable and, best of all, does it out of your sight. People tend to replace this stuff only when the white stuff begins to look bad. That's about twice as long as it should have been on the boat.
Modern conventional wisdom specifies 1x19 (rigging) cable for lifelines. In fact the ORC prohibits any offshore racing boat from having anything else. 1x19 is stronger, less prone to corrosion, smoother (not like naked 7x7 which is full of burrs to snag your skin), stiffer (but lifelines do not have to bend round halyard sheaves), and best of all does NOT come with that horrid white stuff that goes chalky over time, collects grease and bird-poop stains and demands way more time than it's worth in keeping it clean.
The other consideration is for the hardware. Good solid machine-swage fittings, as from Hayn or C Sherman Johnson, work as well on 1x19 as they do on 7x7 (the machine swage is actually overkill on the weaker 7x7). And it is absolutely vital that you use ONLY machine-swage hardware. Rigging Only tell you in their catalogue, in BOLD letters, 'WE DO NOT SELL HAND-CRIMP LIFELINE HARDWARE'. First of all, hand-crimp will not work on 1x19. Hand-crimp is for small racing dinghy shrouds and for hanging porch swings. It is not for anything that might need to save you from flying across the deck in 60 MPH of wind into 20-foot waves in the dead of night when it's the only thing keeping you from a watery unmarked grave that you won't even get to relax in till you get to tread water for 30 minutes of hypothermia watching your boat sail away without you first.
Also, and this goes without saying, the fewer ends with hardware swaged to them at all the better you are. On Diana I have (count them) FOUR separate lengths of lifelines on each side, including the secondary, upper, length from the forward stanchion to the pulpit that can be removed to let out the jib. This is not good; but it kind of has to be what it is to do the job right. Therefore it is all 5/32" 1x19 rigging-grade cable, with cast-SS Hayn rigging-grade fittings (and the fabricated-SS CSJ pelican hook, because I like it), with bronze-bodied open turnbuckles with appropriate cotter rings to keep them from turning.
(BTW I was not fond of Suncor's lifeline hardware which we installed on the latest C44. It was clunky, HEAVY, poorly polished and awkward to install and adjust. I'll stick with old standbys that I know well.)
So I have basically a bulletproof system, but it's adequate for clipping the harness to it; and I really don't see a point to having lifelines at all if they won't support your harness cord.
