Lewmar old standard lens replacement.
Apr 7, 2011
3
Hunter 42 Passage Alameda, CA
I have a 1994 42 Hunter Passage. Any tips on removing and replacing the old standard lens? I have already purchased the replacement lens from Hatch Masters.
Jan 4, 2006
6,519
Check the archives. Enough material on hatch and portlight replacement in there to keep you reading for a month or better.
Aug 18, 2018
118
Hunter 410 MDR
On my 99 410 the Lewmar old standard lenses where not owner replaceable according to lewmar. I have been told a "shop" could have replaced the old standard one, I'm not sure about that. When you buy the new matching low profile hatches the lens is replaceable, the frame can be unscrewed and taken apart.
My old ones, the plastic parts were also brittle and parts where failing on some.
Dec 25, 2000
5,753
Hi Ted, ours remain original, however a bit crazed and have been thinking about replacing. Do you mean the ones in the aft cabin? It seems to me you can unbolt the old lens from the frame hinges and replace with new. Do the new lenses have predrilled holes for the hinges and locking levers?
