LED bulbs
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
The thing about LEDs is that they aren't really "bulbs"--they're one or more LEDs and some electronics. You want good LEDs and you definitely want good electronics and good packaging so the voltage to the LEDs is controlled nicely, things don't overheat, and so you aren't emitting a bunch of radio interference. It's unlikely you've got the good electronics at that price.
Thanks for the electronics lesson. You are right, I know the quality can't be that good at the price.
So far no interference but I guess time will tell. If they are garbage I will replace them as they die with more expensive or higher quality.
But for now they are just fine.
Regards
Gunni
Mar 16, 2010
5,937
My standard bulb was a 1142. I just went on amazon and searched for LED replacement for
1142 bayonet style bulb.
They have several, from single to ten packs.
So while an 1142 unregulated LED may work well on your boat trailer tail-light, it is a poor option for a battery-driven installation like a boat. Doesn't have the voltage range capacity.
Oct 10, 2011
619
Hello Gunni, The part numbers on the LED's that I purchased on amazon are the exact part numbers that are listed on the conversion chart. How can I tell the difference? I realize they were cheap but they have the exact part numbers.
Can you help me out?
Gunni
Mar 16, 2010
5,937
On a boat you want constant current regulation of your LED lamps because your voltage varies as your 12VDC system voltage changes. If you don't have a constant current chipset controlled LED, your lamps will heat up when your alternator, or shore charger kicks on and voltage goes up. And when your voltage drops off you will get a dimmer lamp. More here. There is also a problem with RFI on your radios with LEDs not designed for boat use.
Feb 17, 2006
5,274
arf145, you are correct. However, some of these LED lights come in a seal package, like a bulb. But I guess it is normal convention to call them bulbs anyway. Just like adding a second wireless phone is referred to as a "second line" where there is no "line" per se.
arf145
Nov 4, 2010
498
Beneteau 331 Deale, MD
Absolutely. I wasn't really nitpicking semantics there so much as trying to point out that they aren't the simple commodities that old light bulbs were.
Ward H
Nov 7, 2011
3,832
I played with LEDs in my G Scale trains. First was to just put a resister in line with the LED. That worked but with varying voltage the light intensity would vary. When I reversed polarity the LED, which should not have been on, would glow dimly. Built constant polarity and voltage boards. Then trying to find the right color led. Blue White did not seem right on an old steam loco.
Then if you read about light waves and how a blue white LED seen through a red lens gives a purplish color it gets a bit complicated. Most of the auto LEDs seem to be bright white, not the warm white we might want in our cabins.
I thought about the automotive LED replacements for my 1157 bulbs but I agree with arf145. LEDs are just not as simple as filament bulbs.
Too many choices, too little time and money.
Or as Stu would say "Your boat, Your choice!"
Jun 6, 2006
6,990
On the topic of RFI and LEDs. You will not get RFI from a straight LED (and voltage dropping resistor) . You get the RFI from bulbs that have some sort of voltage regulation. If you are getting RFI from your bulbs it is pretty easy to add a cap and or coil to the circuit to quiet it down.
