Leaky Ice/Box Cooler
1
S2 27 Chicago
I have a 1979 27' S2 and when we use the cooler the area around the steps get wet. Any ideas?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
just a hunch ...sounds like your drain hose is broken or disconected...i have a 9.2 (30 footer) and the drain hose is located in that area and drains to the bilge ...so i would start looking there first ......one other thought heven forbid your box bottom or side may be broken ...but ck the hose thing first...hope this helps
regards
woody
Aug 14, 2011
2
S2 7.0 Echo Bay
I have the same problem. Can the hose be checked by unscrewing the hose fitting from inside the box? There is no access to the underside if the box
