Hunter 31, 1987: I have rain water cascading down the inside bulkhead wall between the engine area and the small wall directly above the engine shelf.
I have been in the rain with it and hosed the decks, roof and the roof/line cover.
It definitely is coming from the starboard side of the hatch area, in the neighborhood where the lines feed from the mast to the clutches (the roof/cover). The channels that take the water away from the roof/cover, was caulked with silicone, recently removed, I have run a hose on the hatch cover itself and watched a ton of dirt, leaves and what not come out of the chanel that is feed from this area. At the same time I have water coming down the inside cabin wall and then into the engine compartment.
I guess my question comes down to this, the roof cover needs to be addressed, wether removed or cut loose.
Has anyone ever done it successfully.
