Bill
The mast boot on our keel step mast is leaking. The boat is a 1995 Catalina 36 MkII. The water appears to enter between the mast and the boot, inspite of tightening the strap clamp as tight as possible. The boot is in good shape, it just does not make contact all the way around the mast. Should I consider using a caulk between the boot and the mast, a gasket of some sort, or something else to cure the problem?
