After recent rains we had dirty brown water leaking off the starboard middle and forward chain plate bolts on our 1996 Catalina 30 MKIII. After removing the fittings I cleaned and prepped the holes for rebedding with 4200.
I also drilled a small hole aft under the side deck between the middle and aft chain plates to check for leaks. Sure enough, a small amount of water drained out which suggests the deck core is wet in the chain plate area.
The leaks are new, the deck is still hard and seems solid. I plan to get a moisture meter but I expect a positive reading. I'm sure the 4200 will seal the chain plate leaks from above. Once rebedded, shall I drill more weep holes to explore and let the deck empty and dry? Will it? Or am i looking at a major project? Although 28 years old, she's a terrific boat and we've kept her in very good condition.
Thanks,
Tim
Thanks,
Tim
