AHOY I would appre. any inf. on repairing gaskets or whatever you do to stop water from leaking in the cabin windows (not the port holes) but the actual cabin windows. THKS ALOT
Mike,Probably not what you want to hear, but the best bet is to rebed. Take them out, clean the gunk, rebed with life caulk. No more leaks and you get to inspect the area around the windows/ports for any water intrusion/damage. If you find the latter, then West System epoxy with a thickener and some time will take care of that. Daves/v Wind Dreamer II
