Leak through deck into cabin
Oct 9, 2023
17
Hunter 34 2 Bellingham
My 1984 Hunter-34 has a leak that results in rainwater slowly running down the inner hull, making the carpet wet. I cannot tell which through-deck bolts are leaking. I started off by re-sealing 10 bolts that secure the genoa traveller to the deck. It is still leaking. Now I am wondering if a leak in the toe rail bolts would result in water running down the inner hull. I am attaching a picture. What do you think?
-na -NA Anywhere USA
An old trick to find topside leaks is to pressurize the cabin and to locate air bubbling out with someone brushing every fitting with soapy water. To do this, you will need to close ports and tape down the entire companionway with a large piece of plastic. Then cut a small slit in the plastic and insert a leaf blower tube while sealing the tube with tape to. Start the blower and have a second person start brushing.
Your description of the leak inside needs to be more specific as to location and a photo or two would be helpful
Nov 6, 2006
10,152
The design of the H-34 toe rail is such that it is unlikely (not impossible) that rainwater can come in. I would suspect the fixed portlights or the opening port over the galley that you've pictured. The hull has an outward turned flange; the deck has a "shoebox" fit over that flange and the toe rail bolts are outboard of the hull. A very loose bolt could pass rainwater; Get a good sized philips head driver and hold the heads in place while you tighten each nut with a small socket (tied to your arm so it doesn't go for a swim). Snug down each one.. Not too tightly, snug. (probably something like 60-70 inch pounds..) n start looking at the other stuff. Dave is right about the pressure leak detection.
Happy leak hunting!
Water is evil when it is leaking into your boat. It will most often flow with gravity from the top of the boat. Drip downwards. Hit an internal hard service (like a liner), then fall to the floor and come out, making it look like it is coming down the hull sides, but it is not. Pure Evil.
Try the pressureize trick mentioned by @Crazy Dave Condon. It works. Use a hose to spray water over small spaces on the hull, covering all areas around the suspected leak, as suggested by @Don S/V ILLusion.
Or get inside the boat during a rain storm and sprinkle some chalk in the likely spots to see if you can track the leak back to its source. You can also try to cover the suspicious areas with plastic wrap to see if you can eliminate the fixtures.
While tracks are always a possibility, I have found Winches, hatches, ports, chain plates, and deck handholds to be the usual suspects. I discovered during the last rain that one of my port frames was collecting water. Water was wicking up between the glass and the frame due to a poor seal (air bubbles in the seal material) between the glass and the frame. The solution (cover the frame until I can properly repair it) is to create a weep hole in the frame to drain water onto the deck, then reinstall the glass with a proper seal.
PJL
Apr 22, 2014
53
Hunter 42 Nuevo Vallarta, Mexico
Another place to check is the mast step. Use a thin rod to make sure its weep holes are cleaned out (do this every season). If you pull the mast for any reason, check the filler at steps bottom for cracks. Also, increase the height of the riser where the wiring enters; make sure its base is well sealed, too. Had to do all of these for my Passage 42.
BW1973
May 11, 2019
10
Hunter 340 OGYB
The 'leaf blower wet down the boat with soapy water' pressure test worked on my 2001 Hunter 340 very well. Also visit the boat during a rainstorm and see where the water gets in. I had a drip around a starboard fixed port in the main cabin. resealed it inside and outside with Boatlife. I waited a week and retested the port with a buddy spraying the port with a hose. We tested each fixed and opening port every month or so. So far so good.
BW1973
May 11, 2019
10
Hunter 340 OGYB
PS winter with the snow on
the topsides, the freeze thaw cycle and rain will be the real test. Expect new leaks as a fact of life.
