Leak at rudder post
Matt Niemic
Water comming in at topof rudder post. can thisbe fixed with out removing rudder?
Jim Nixon
me to
Matt There is 2 ways to get water in your boat at the rudder post. 1 is from the bootom of the boat there is a packing for that. 2 from the top, I had the same problem and have not been able to eleminate it completly. I slowed it down by deverting the water that comes around the rear hatch it funnels right on top of the rudder post. I used 3m 4200 to make small dams to get the water started down befor the post. Good Luck Jim Nixon Catalina 30 #1486 PS check the arcives I think there were some mention of this
L
Lauraine
You're not alone,Matt!
We've had our boat for three years now and we're still trying to solve that problem. Short of redesigning the whole thing, I'm not sure there is a fix. If you find one, please let us all know! Good luck!!
E
Eric Ludin
What size packing for rudder post?
I repacked my stuffing box for the rudder post using 3/16" packing. Unfortunately, it now leaks more than before. I'm pretty sure I must've used the wrong size packing. Anyone know what size packing I'm supposed to use??? Many thanks.
PAT
RUDDER POST LEAK
I had a small amount of water running down the rudder post and then leaking into the quaterberth. I removed the wood divider at the aft end of the q/berth and attached a piece of plastic to keep the water from entering the cabin. A very cheap fix and so far works great.
