My boat is 14 years old. 2003 386 with all of the toys. I have had a very small drip at the mast post for years. It progressively got worse this year having sailed multiple events of 3 to 6 foot waves and 25 to 30 knotts of wind. I suspect that the bedding of the mast plates on deck are in need of maintenance (redo). I have ruled out everything else, and with water tests. I have a few questions to those that have had to do this type of work. Are the original mast plates done with 5200? How much work is required to lift them to reset? and is 4200 sufficient or should I use 5200? I am taking the opportunity to replace VHF antenna, TV digital antenna, installing a loud hailer to my new Horizon AIS system, new LED light at the top of the mast Windex and Anomometer are new, no need to go there. Any advice would be appreciated. I have done all of the worked needed on this boat for the last 11 years. Mast removal and replacement by others. I do own a cable tension measurement device for fine tuning when the time comes.
