I posted this earlier on the Catalina 310 owners group. It was suggested by a wiser SOer that I might get more responses if I crossposted it at Ask All Sailors. So here it goes.
Hello all,
Looking any ideas for the installation of a full boat inverter. I had been going back and forth about weather a 2000 watt inverter or a Honda 2000 watt generator was the way to go to set our boat up for our long term cruise. After spending a couple of days in Edgartown on a mooring next to a power boat that ran their generator non-stop I have decided I can't be that guy.
So some basics:
1) the main reason I want a large inverter is to run items like power tools. Running things like the TV, laptop or microwave isn't really a concern bc we will either not have those items when we leave (like the microwave) or they are already 12 volt (like the TV and laptop charger). But I would like to be able to run a corded drill, dremel, saber saw etc. Being able to use the electric kettle to boil water for coffee would be nice too but I can always use the stove for that.
2) from my research so far it seems that pure sine wave is the way to go. Please tell me if I am mistaken because the cost of modified sine wave is so much cheaper.
3) I am open to an inverter/charger combo. My current charger is slightly under sized at 40 amp. But again cost seems to be a big factor here. Combos seem to be around $2K while a straight inverter can be under $1K. I don't necessarily need to upgrade my charger because it does the job and when we leave to go cruising we will be adding solar and on the hook almost all the time.
4) my primary battery bank consists of 4 6-volt golf cart batteries for a combined 460 Ah at 12 volts. I presume this will be large enough to run power tools for a short period of time without drawing the bank down too far based on looking at the specs. But some real world data is always helpful.
5) not running AC or anything like that. Don't have it and don't want it.
So if you have any suggestions on inverters or inverter/charger combos brands, ideas on where to install one or experience in using inverters of this size I would appreciate some replies.
I am currently leaning towards the Go Power 2000-watt pure sine wave inverter due to cost. But need to do more research on the brand. We have a Go Power 300-watt modified sine wave inverter on the boat now that was installed by the PO. Has worked fine but we don't use it very much.
Thanks and fair winds,
Jesse
Hello all,
So some basics:
Jesse
