Does anybody knows where should be connected the 2 houses from the oil cooler?
That's a tough call. I would suspect the oil cooler is in series with engine heat exchanger but is it before or after ? That's the big question here. Getting the order reversed could cause problems for one system or the other.I need to figure out and attach it to the heat exchange from the new engine.
