kiwi prop - shaft rotates in neutral
Pat
Installed a Kiwi prop this Spring. Works ok except that the shaft rotates in neutral when I shut the engine off. I have to put it in reverse to stop the rotation. This makes me think that the blades are not totally feathered? Any one else have this experience? Thanks.
Rick D
Jun 14, 2008
7,204
Not A Problem IMHO
I have a geared folding prop. It will continue to rotate unless I put it in reverse. It then folds and I can put it in neutral and it will not rotate. RD
Pat
I tried that too ....
but when I shift back to neutral from reverse it starts to rotate again. Thanks Rick.
Brian M H23
How fast does it rotate??
How fast does it rotate? I mean, the obviously isnt much friction in the system, so a little tiny bit of pressure one way or the other, even a little bit of sideslip inthe water, is going to cause some rotation. The only way to *stop* it is to actually put some resistance on the shaft, which is unnecessary. maybe try grabbing the shaft with a leater glove and see how hard it is to stop?
Pat
It doesn't rotate very fast
....but if the blades would be constantly moving to feather I would think there would be no rotation?
Rick D
Jun 14, 2008
7,204
What Does the Dealer Say?
...or the manufacturer? They were quick to repond when I discussed buying one. I passed on it based on the horsepower limit; I was queezy being at the upper end. Rick D.
shorty
Apr 14, 2005
298
Pearson P34 Mt Desert, ME
same experience
Installed this spring, Rotates slowly in neutral. Kiwi said that might happen. I too wonder if it is not feathering properly but do not worry too much about it. Sail in reverse. Love the prop. Replaced a two blade. Better thrust forward, way better reverse, lots easier docking. Less drag sailing? I think so.
