Keel dimension
jphud
Nov 18, 2010
70
1980 Hunter 37 C Saugerties
Good Day,
Can someone provide the keel height for a 1977 Hunter 30. I am trying to get costs for trucking the boat.
Thanks,
John
Sep 10, 2009
194
Hunter cutter 37 1981 St-lambert
If you have the specifications drawing under your hand, I would do a rule of third to get that dimension. Meaning if your 30 foot boat is 6 inches on the drawing, and your keel is 1in, then the depth of your boat is 5 foot...
5,802
There were two keels, 4' and 5' 3". You might need to know which. I say 'might' because a hauler like I used could handle either so long as there is nothing higher on the boat than the cabin trunk. This was an actual boat hauling trailer where the keel was less than 12" from the road. This gives plenty of clearance.
jphud
Nov 18, 2010
70
Thanks, I was able to get to the boat and measure. It appears to be 3' 8", guessing that would be the 4'?
jphud
Nov 18, 2010
70
Would you know aprox where the stub ends and the lead starts. Boat has small smile.
5,802
The "smile" is most often at the forward edge of the hull to keel joining. On my boat you can follow that back and see the joint clearly. You can also tap on the two parts to hear a distinct difference between the glass and the lead.
