K
Kevin Walsh
This is a follow up response to an earlier thread on O’day 22 keel cracks. I repaired a hull crack at the forward end of the keel where it meets the hull with Marine Tex. It has been in the water about four times since the repair. I check it every time to see if it is still holding and this last time it failed. The crack has reappeared in the same location. It looks like it is time for glass and epoxy. There were some previous posts about this also. One person used a triangular shaped piece of wood to extend the keel. I think I am going to try that approach too see if it works. One last thought, my boat sits on bunks when tailoring and the keel is unsupported. In a previous post, Lee say the manual for his 222 says to trailer with 80% of the weight on the keel and 20% on the bunks. I am going to modify my trailer to support the keel. I would appreciate any input on all or any of this. I have included a picture of the repair. The crack is inside the red area. To repair it, I made a 3/4" wide valley with a belt sander and filled it with Marine Tex. I added a little PC Marine apoxy puddy to fill in a little more and the used some black paint to make the crack more visible if "when" it reappeared.Thanks,Kevin
