Keel crack at hull O'Day 30 ('82)
pcrice
Jul 2, 2019
2
oday 30 IL
Had a lot of fiberglassing to do. Wanted to make sure there were no keel bolts. Hard to dry out. Drilled a lot of holes. Cement and water still seeping from bottom. Overlaid layers of fiberglass at crack. Not pretty...but didn't want to risk keel dropping further (1/8").
Seems to be holding.Bildge pump doesn't run this season, but there is always 1/2" water in bilge (water seeking its own level). End of season will drill more holes and let dry all winter again.
in
5,862
Oday 322 East Chicago, IN
Yikes! That looks like a hot mess. Glad to hear she is holding out the water (mostly).
I found a small crack on the leading edge of my rudder just before splashing this spring…
I didnt want it to get worse, so did a quick fiberglass repair job on it and I think all is well, but will inspect it carefully for water ingress when I haul out in October…freezing weather can play havoc on our boats.
B0628F57-E565-408E-AFA8-E22795C07449.jpeg E2A20729-F240-4D4D-B3E6-C6E9C0BD6893.jpeg 13F3AA09-F289-4B8C-97AB-21F7206FF375.jpeg 6CDD87CF-93A9-4EFE-BD82-793AA1729AD1.jpeg
Good luck with the project.
Greg
Likes: pcrice
pcrice
Jul 2, 2019
2
oday 30 IL
View attachment 196042 View attachment 196043 View attachment 196044 View attachment 196045
Greg
Thanks Greg. After it was sanded, primed, and painted....it didn't look so bad... but it worked...we must do what we must DO :)
