New project boat, the two issues that need my immediate attention are the rudder and keel.
The leading edge of the keel has a section peeling off, looks like delamination. Not sure the construction of these keels, is this just layers of paint/fairing or is this fiberglass peeling off? Once I grind this out to iron/lead would I fill with fairing and prime/paint or fill with fiberglass.
I'll remove the rudder to repair at home. Should I cut the whole side off this rudder with how bad it looks? I'm open to replacing the core if needed but unsure of how common these rudders fail like this.
Thanks for any advise.
