one example
Skip Randall of the s/v “Nehalennia” (Baba 30) offered this on the Take Her Sailing forum “The Virtual Anchorage” - http://www.takehersailing.com/quoteHi Gord, here's the details on how I wired up the wind generator and the solar panels. For the wind generator, the + & - leads run first to a dipole toggle switch on the electrical panel, with one throw completing the circuit to the regulator, and the other to a loop which shorts the generator (and brakes it for tying it off). The regulator is one sold with the generator, and has 3 resistors to dump off current when the batteries are topped off.In practice, I tie off the blades when a big blow is coming and when I'm on shore power. In prep for Ivan, I took the blades down entirely. The leads from the wind generator regulator go directly to the ganged house batteries (the two AGM 8-D's). As for the solar panels, the wires are led to a dedicated regulator manufactured for solar panels, and from there directly to the battery lugs. There is a simple on/off switch between the panels and the regulator that allows me to switch them off when the batteries are topped off. If I don't (switch them off), the regulator attenuates the charge anyway, and since the amps are much less than the wind generator (8-9 volts, max), they don't require the resistor array. I also have a high-output alternator on the engine (120v ample power) that has it's own "smart" regulator. All three charging sources can be active at the same time, all with their dedicated regulators, and the composite system works well. I know it's somewhat complicated with 3 seperate regulators, but it has worked relatively trouble-free for 6 years. The engine alternator regulator (ample power) did go tits up 6 mos. ago, and I replaced it with a new solid state unit from west marine (I 'm blanking on the manufacturer) which is working well. I hope this info is helpful for you. Regards, Skipend quote
