Jiffy Reefing Mast ?
Ross
Jun 15, 2004
14,693
Brian, it is spelled
champagne not chaperone!;)
Joe
Jun 1, 2004
8,342
Tabernacle....
After reading all these comments....it is apparent that the much safer and saner stragegy would be to equip the boat with a tabernacle mast that would allow it to be tipped forward the required 20 degress using the halyards, stays and shrouds to control it. Instead of $175 per pass, I think the mast alteration is a better investment. There are a few larger sailboats here in Mission Bay that moor over at Sea World, beyond the 40 ft Mission Bay Drive bridge. I watched a single handing skipper tilt his mast forward about 30-45 degrees to easily clear the bridge. Pretty neat!
Oct 25, 2005
735
Catalina 30 Banderas Bay, Mexico
Rated PG-13
I think that we could get a PG-13 rating with a combination of football players, cheerleaders, yorkies, bowling balls and a dinghy using a tabernacle to lower a sailor's mast to fit under a bridge ... I think I've heard that if it stays up for more than 4 hours you should call your doctor ... Seriously, If a boat has to pass under a bridge on a regular basis, adding a tabernacle to the mast becomes viable. Doing it right requires a bit of engineering and considerable expense. Deck stepped masts are easier to convert than keel stepped masts. It would be much less expensive to cut the mast down and have a square top main built to get the sail area back. For a one or two time shot, heeling the boat makes the most sense ... particularly if it involves cheerleaders ... ;)
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
ah yes
co-ed naked cheerleader hanging from a haylard. That sounds like a great spectater sport. Come to think of it, you can leave off the co-ed part.
sailortonyb
Bridge Ducking
Let me just say that bridge ducking is not going to be a hobby. It was just a thought that if it was too rough on the outside, the ICW can be used....maybe? Hmmmmmmmmm? Anyway, I have a keel stepped main mast, so tilting the mast would not work, at least not without a hacksaw. The boat seems to heel fairly easily, but for those that have been gracious enough to do some calculations, here is what I got....An Allied Mistress 39 ' Ketch. Displ.= 20,800 lbs., Beam = 12', Mast Height = 49'-6", Not sure of the boom length, I'll guess at about 12 feet. I'll definately test out the dinghy idea first. Thanks for all of your help.
