I am attempting to replace the two "jib sheet blocks" on may 77' Oday 22, they are spirng loaded and appear to be of one piece construction. This basic item has been hard to locate, any help is greatly appreciated.
The nylon roller on my "stand-up" block (That's what the jib block is called) is partially broken. At some point I will have to replace it as well. I recently had Shaefer Marine repair the bearings in my roller furling unit and in the process, I discovered that most of the hardware on my 25' 1983 is Schaefer Marine. They were very helpful and sent me a catalog with prices that included the blocks that you need with full specifications.
Thanks Ugadawg,I found exactly the item you suggested on Reply #2, the one I ordered is item # SCH03-62, the Schaefer 37mm Stand-Up Swivel Block. Thanks for your assistance.
