Rob, have mine running the port side .
because I use that side less. I almost always go forward from the starboard side. I have the furler line running thru fairleads on the outside of the pulpit and stancions through fairleads mounted on the posts of the pulpit and stanchions and then up to a Johnson cleat on the stanchion just forward of the cockpit. It has worked great since I installed this set setup on my first O'Day 25 cb.The wrap of the furler depends in the side the UV was installed on the sail. The first furling sail I bought had the UV on the Port side. What is nice about the CDI furler is that the drum can be rotated in many directions. This must be done before stepping the mast but if you look on the bottom of the furler there are a number of holes in different positions. So, It doesn't matter which side the UV is on, the drum can be directed for the line to run down either side of the boat. My furler opening aims 45 degrees to port.My furler line enters the drum on the starboard side of the drum and it is aimed directly at the forward port post of my pulpit where the first fairlead is connected.If the UV is on the port side the line will enter the drum on the starboard side and viseversa.r.w.landau
