Jackline
No comment on the halyard approach, other than that it generally sounds like a bad idea.Having read lots of the old threads on this, I think it is pretty much subject to common sense. I very much disagree with the "running it outside the lifelines", or even the "one on each side of the boat" approaches. Getting dragged alongside the boat at 5-6 knots is pointless, and will get you killed. The point of a jackline has to be to keep you onboard the boat if you lose your balance, or get hit by a wave.With this in mind, I put a strong padeye up on the arch on our H306, maybe a foot to starboard of center, and ran a jackline from the padeye, past the mast on the port side (it doesn't interfere with the running rigging), and secure it at the port-side bow cleat. If I shorten the tether to around 4 feet long, it isn't possible for me to go over the side, except possibly up near the bow cleat, where I've never been when alone. This system feels safe to me, and I can't see pulling out the bow cleat or the padeye (which is bolted to the steel webbing in the arch, not to fiberglass). The West Marine jackline I bought has plenty of stretch. This setup wouldn't work for most people on older Hunters, but I'd recommend it if you have a (solid) arch, such as on a newer Hunter.Jay
