Hauling your boat
A few suggestions:First, check the ramp out carefully a day or two ahead of time. You need to know the water depth (at low tide), the condition of the ramp between the low tide and high tide lines (available traction), where the end of the ramp is and whether or not there is a drop-off beyond the end (so you don't back the trailer over the edge). You should also practice maneuvering the tow vehicle and trailer in reverse on a deserted parking lot. It will pay off when you're at the top of the ramp.Get help, preferably from someone who owns a trailerable sailboat (powerboaters don't do it the same way). Review the procedures with your assistant and agree on who does what and when. A checklist helps.Haul the boat on a weekday if you can, so you can take your time. Make sure your tires have the proper pressure and the wheel bearings are well packed with grease. Have all your trailering gear handy... stern tie-downs, mast-lowering rig, wheel chocks, etc. A hose and a source of fresh water are handy for washing the boat down. Bring a bucket or "earmuffs" to flush the outboard, as well as a scrub brush and some clothes you can get dirty in.On the fateful day, position the trailer close to the ramp. If your trailer has an extendable tongue, use it (it will help keep your truck's tires out of the water). Check the ramp for excess weeds and clear them away. Go aboard the boat, attach docklines at bow and stern, raise the centerboard if you can, bring the boat alongside the leeward side of the dock and tie off with some slack in the lines.Back the trailer slowly into the water until it is just deep enough for the boat to float on. Set the parking brake and chock the front wheel on the drivers side. Maneuver the boat onto the trailer. Clip the bow strap into the towing eye and winch the boat tight onto the trailer. Be careful, because if the boat hangs up somewhere you could rip the tow eye out. Check to make sure the boat is centered on the trailer, then pull it up the ramp slowly, steering the tow vehicle so the rear wheel misses the chock under the front wheel. At the top of the ramp, check again to make sure the boat is still centered. If not, back down the ramp until the boat just floats free, center it and pull up again.Once clear of the ramp, stop briefly and go back to make sure you haven't left anything behind on the ramp or the dock. Retract the extendable tongue. Attach rear tie-downs. Connect the trailer electrical wiring plug.Now comes the fun part...the washdown. I like to scrub the hull while it's still wet because the algae and any marine growth are still soft. If you have antifouling bottom paint, wear rain gear to protect your skin. Once the hull is clean, rinse the deck and topsides.Flush the outboard, either by submerging the lower unit in a bucket of fresh water or placing the "earmuff" over the water intake. Shut the fuel off, start the motor and let it run at a fast idle until it stops. Later when the engine is cool, remove the spark plugs, squeeze a few drops of Marvel Mystery Oil into the cylinder(s) and pull the starter cord slowly to turn the engine over and coat the cylinder walls with oil. Put the plugs back in loosely. You can check the gear oil in the lower unit later but don't wait too long in case there is water in it.There's still the matter of lowering the mast and securing the rig for towing, but I'll stop here. This is not an all-inclusive list but I think I hit the main points. I'm sure other people will have more things to add. Good luck.PeterH23 "Raven"
