It's 2014-Do you know where your keel bolts are-torque wise?
Sep 23, 2009
1,480
On my very new to me '84 I recently checked the torque on my keel bolts just 'cause the surveyor said to. Some were no more than 20-40 lbs vs the 160 they should be!
With all the recent press on lost keels, our 70-80s era boats may need a quick check.
Aug 3, 2012
2,542
Is the 160 correct for all the O'Day keels? I have the 272.
Thanks,
Andrew
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Re: It's 2014-Do you know where your keel bolts are-torque w
Yep, just retorqued mine recently. Chief
Aug 3, 2012
2,542
Well then, I guess I will take my torque wrench and add that to my list of chores while we are refurbishing the boat!
Thanks,
Andrew
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Be careful. Check the size of the bolt then get a recommended torque from a table for the material. The 3/4 inch bolts on a 34 are probably higher than the bolts on a 27. 160 foot pounds is a huge amount of clamping force.
Pat
Jun 7, 2004
1,250
I was reading the manual today for my 272 and it noted the 272 has 3/4 in bolts as well.
Mine appear to be fine. No leaks below..Thankfully, pat
