- Oct 22, 2014
- 24,519
Yes it is spring. One of the rites of spring is a check of your never used in anger PFD.
For you guys with the solid floaties, this is easy... throw it in the bathtub or a near by body of clean water. If it floats test 1 complete. Take it out dry it and check all of the buckles and belts for function, clean and no damage.
Good to go.
Now you sailors with the high tech gas powered, water triggered, super bladder PFD's.
Time is now to do the 16 hour is is still inflated test. Sure your doing regular maintenance - the clean and oral inflate, then repack functions every 2 months (https://www.mustangsurvival.com/en_US/html-module/pfd-inspection-maintenance.html).
And you know that if it says 2018 on the unit, you have until December 2018 before you need to rearm the vest. And you are keenly aware that you have to replace the whole kit. So now is the time to jump in the water and see if the thing actually works... Or if you live in the cold water climate put the vest on a friend and push him off the end of the dock shouting It's a Test... It's a test.... No that is not the way - unless you have a lot of rum on the boat and can wipe the experience from his/her mind.
But it is a good thing to see if these safety tools actually work at some point in your boating life. And nothing like when you have to throw out the outdated parts to give them a test.
How to rearm your PFD HIT life saving vest.
I just replaced 1 of my 3 kits.
Now it is time to visit the with CG Aux and get that inspection sticker. Maybe it will work as good as it did last year. No on water stops.
Good to go.
