ISO teak bow sprit for 1985 Catalina 27
May 24, 2004
7,237
CC 30 South Florida
What is the thickness of that bowsprit? Would there be a composite material block that could withstand the compression and its integrity over time? Perhaps it would be simpler just to go with the time tested teak. Ift it lasts another 30+ years I think that would be enough. I think it would work for a template, you can get the shape and measurements.
Likes: Rudderless
Apr 5, 2009
3,334
Take a look under the bow sprit, there should be some kind of adjustment mechanism on the bobstay, likely a turnbuckle. Loosen the turnbuckle after securing the mast. Easing backstay tension and shroud tension will also help.
The C27 and C30 boats with the bow sprit option did not come from the factory with an adjustable bob stay. Many of us have added that when we rerigged the boat but you will still find many of them without the turnbuckle.
I am not sure which furler he has but it appears that there is a turnbuckle built into the furler drum based on how much treading is showing. I would suggest he look online to find the manual that will tell him how to loosen it.
Likes: Rudderless
Nov 14, 2026
9
Catalina 27 Waukeegan, IL
Yes, I found the manual for the furler and it does show that adjusting the forestay is done through the furler drum.
Nov 14, 2026
9
Do you have two mast head halyards or only one? How about a spin halyard?
I would take two halyards from the mast - preferably two mast head halyards - and run them to the bow cleats, one on each side and tighten them up. Then loosen up the aft stern stay. This should relax the tension on your forehead stay.
Check the tension on all stays and shrouds before doing this so you have an idea of any changes in tension on any of these. If you have swept back spreaders, you may find tension in those shrouds.
Just work slow and check all the tensions - it will become self evident...
dj
Yeah, I did that the moment the bow sprit cracked. I ran both the jib and spinnaker halyards to the bow cleats.
My issue now is that since the boat has been shrink wrapped already, I can't really get in there and do what I need to do.
I'll wait till the Spring as opposed to cutting the wrap and having to retape it.
