ISO teak bow sprit for 1985 Catalina 27
Nov 14, 2026
9
Catalina 27 Waukeegan, IL
Ahoy everyone,
Where could I find the teak bow sprit for my Catalina 27? What seems to be the original one was rotted and finally cracked.
Thanks in advance.
Welcome to SBO.
One place to start might be the parts manual. It can be found in the Catalina 27 owners' resource section of the site.
You might also search the SBO Store here. A lot of Catalina parts are available.
If that is unsuccessful... Try Catalina Direct. Bit expensive, I am told, but again, parts are often available.
And a last resort is to take your current part and use it as a template. White Oak or even Ipe are potential long-lasting woods for boats in fresh water. That is, if your DIY wood skills are fair. It would be a good project to test your woodworking talents. Boat Owners save boat bucks by applying DIY skills to many of the things that will require fixing.
Likes: Rudderless
Nov 14, 2026
9
Welcome to SBO.
Thanks for the reply.
If I were to use white oak, what kind of sealer would I use? Same kind as teak?
The original one may not work as a template.
Sure, it can.
Between the wood parts on your boat and the image from Catalina Direct, you can create a template that will work. Note that the CD parts are not identical to your part shape on your boat. The wood is not what is holding your forestay in place. It is the wire (the bobstay) that runs to the bow of your boat beneath the sprit. The wood (sprit) positions the Bobstay/Forestay forward of the bow. It stops the two stays from collapsing toward the bow.
Talk to the folks at Total Boat. They sell varnish and sealant for this type of job.
Be sure you select the oak piece with a good, strong grain orientation. Talk to the wood shop source of your oak about the grain and the purpose for the wood. You will learn a lot of details that will help you going forward with this and future projects.
I wouldn't use White Oak. It has a tendency to craze and split. I used it for knees on my Marblehead Skiff and both sides failed. They were sawn into the el shape. The bow sprit is a different application. But, I don't know if a coating will help with the cracking.
I don't want to spend your money but the above referenced Catalina Direct part # H1726 at $186 seems like a good deal.
Likes: Rudderless
dmax
Jul 29, 2018
1,362
Telstar 28 Buzzards Bay
Agree that sealed oak doesn't do that well long term when exposed to the elements, 2 - 3 years maybe. Go with teak.
Likes: Rudderless
dLj
Mar 23, 2017
5,276
I'm not a fan of teak used in a bow sprit. It's OK, but there are other woods I feel are more appropriate. The list is actually long so I'll only mention a couple
I would prefer iroko. Sapelli is another good wood in that application. White oak would work also but you have to be especially conscience of grain orientation. Keeping grain orientation is good in all cases but white oak particularly.
The premade one @shemandr mentioned sure looks like the easiest option and the price is quite reasonable.
dj
Likes: Rudderless
Nov 14, 2026
9
dj
Yes, the premade one from Catalina Direct is the easiest option but because of supply chain issues, it's on back order and could be a while before it becomes available again. This is why I'm already looking at the option of fabricating it myself even though I'm not a wood guy at all.
dLj
Mar 23, 2017
5,276
When you say you aren't a "wood guy at all" - can you clarify that a bit?
What do you have for wood working tools? Got a joiner or planer? Table saw? Clamps? If you don't have some of the basics for wood working tools - is there like a makers shop or some such thing close to you that is available for a project like this? If you don't have any wood working tools now - to buy them will cost you more than the value of that piece. Jus' sayin'...
dj
Likes: Rudderless
The problem with DIY fabrication is that you’ll probably have to buy a whole board to get that piece out of. You may even need to scarf two pieces of a board together to get that width.
I’d find some friendly higher end cabinet shops who might sell you a scrap piece. They are knowledgeable about wood in general.
Is plywood off the table?
Likes: Rudderless
dLj
Mar 23, 2017
5,276
Plywood could be used but to make it look good would be a serious wood working project. Then you have the issue of getting a sufficiently good quality plywood base. I don't know how thick that original piece is but it's probably more than 3/4" thick. If it is then you are likely into laminating plywood as it's difficult to find plywood thicker than 3/4". You'll also have to be careful making sure you fully epoxy encapsulate.
dj
Nov 14, 2026
9
dj
dj
The original teak is 1 1/2" thick.
Plywood just wouldn't be a good idea for this application. I'd use it for a bilge cover but not this.
Nov 14, 2026
9
I will visit a lumber place near me next week. They do deal in exotic woods and do sell "Left over" or scrap pieces.
I might be able to find a big enough piece of Iroko there. They do also do milling to get it down to the right thickness.
I’m not selling plywood especially since you would likely need to buy a whole sheet at heart stopping prices, and then do the laminations to get 1 1/2 “ thickness, but I don’t understand what physical properties the plywood would be short on. Yeah, exposed ends aren’t pretty but marine ply has a long history of reliable service in and on boats. I believe the WWII PT boats were plywood and some of those hulls are still in service.
Your new post just came in. Happy hunting!
Nov 14, 2026
9
So I know that I have to remove this cotter pin and then release the furler from the bow plate, but how do I ease some of the tension on the forestay? It seems to be under a lot of tension even though the bow sprit split in half and the furler is higher than usual.
dLj
Mar 23, 2017
5,276
Do you have two mast head halyards or only one? How about a spin halyard?
I would take two halyards from the mast - preferably two mast head halyards - and run them to the bow cleats, one on each side and tighten them up. Then loosen up the aft stern stay. This should relax the tension on your forehead stay.
Check the tension on all stays and shrouds before doing this so you have an idea of any changes in tension on any of these. If you have swept back spreaders, you may find tension in those shrouds.
Just work slow and check all the tensions - it will become self evident...
dj
Likes: Rudderless
First I would take a halyard and run it to the bow, securing it there. Then I would tension it. This will replace the forestay- holding the mast in place, when you release the forestay during the removal of the furler.
The tension on the halyard may be enough for you to release the forestay. If not easy the back stay a bit.
Take a look under the bow sprit, there should be some kind of adjustment mechanism on the bobstay, likely a turnbuckle. Loosen the turnbuckle after securing the mast. Easing backstay tension and shroud tension will also help.
Likes: Rudderless
