We're in the market this year for an outboard for the dink. We know it will probably only be used a few times a month, and spend most of its time hanging on the stern rail. We also know that most outboard problems are related to fuel, like gummed up carbs from inadequate use, effects of ethanol, etc. So we're looking very hard at the new outboards from Lehr that run on propane. Looks like they were introduced at the Miami Boat Show last month, and both Defender and West Marine are carrying them.
http://www.golehr.com/marine.php
They have the ability to run for an hour or so (quick trips ashore) on the same one lb bottles the grill uses, and can use larger external tanks for longer trips. The biggest obvious advantage is absolutely no fuel problems. The motor can sit in the hot Florida sun for six months and still start easily because there's nothing to gum up the carb. They don't even have a choke.
So while we were looking at that and going "Hmmmm," we then found this:
http://www.yamaha-propane-natural-gas-generators.com/
An authorized Yamaha power equipment dealer that sells Yamaha inverter generators set up for tri-fuel operation (gas, propane, and natural gas) with full factory warranties. Since we were also thinking about picking up one of those small Honda generators this year, and the Yamaha units are supposed to run quieter, longer, and have a better EPA rating than the Honda's, we're wondering if the ideal solution might be to pick up a couple of those new composite propane bottles, maybe the ten pound size, and just go propane for the outboard and generator.
Any obvious disadvantages we're overlooking? Yes, propane can be dangerous, but so is gasoline. The tanks would stay outside the boat. The fuel would never go stale. We already carry propane because of the stove and grill, and this would allow us to go with just diesel and propane and not also have to store gasoline onboard.
We wouldn't be seriously considering it if the prices were outrageous, but there's only about a 10% to 15% premium on the cost of the outboard and generator, and that should be easily recouped through lower maintenance costs.
