I hooked up a disposable 1 lb. tank to test out this propane conversion alcohol stove. IT looks fine if I am going to roast a whole pig.
Hermit all propane stoves or any appliance will have a regulator for proper pressure 11"-14" inches water colume = 6oz pressure . Working gas pressure best to have 12" wc when all appliances are off and 11" flow wnen appliances are on. All propane stoves must have a burner orfice,an average burner is between 10,000 to 15,000 btu the orfice size would be a #63 drill bit for 9,563 btu. which is about the size of a commin pin. hope this can be of some help. I,m lic for propaneI hooked up a disposable 1 lb. tank to test out this propane conversion alcohol stove. IT looks fine if I am going to roast a whole pig.
