Exactly correct, Rich. The seal in fact must not touch the impeller. It is a "lip seal" or sometimes an "oil seal" where the stationary lip touches the rotating shaft. The seal is "pressure energized" in that more pressure makes it seal harder.. That o-ring is in fact a "flinger" whose purpose is to fling any water getting by the seal out the weep holes in the case. Attached is an assembly drawing for the pump on a 3GFMF Yanmar. The bottom right corner shows the fits and stationary and rotating parts..
Yes the grooves are caused by "bits and grits" that get trapped between case and impeller. If they are shallow and small, no problem.
