Is it ever OK to see smoke coming from the alternator ...
Mar 30, 2013
700
I'm not aware of anyone who has successfully reinstalled the smoke without considerable expense.
It takes specialized, wizard like training and involves numerous magical talismans, but in many cases the smoke can be reinstalled. Sometimes it's cheaper to replace the cursed device though.
Yep! That's what I need. Smoke replacement.
Someone up in Canada has a lot of time on their hands.
It has been dark up there for the past 4 months. All the ladies are finished with IT. So time and there hands is all that is left. That and British sports cars that are a bit eccentric.
Likes: BrianRobin
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
(Must be one of those English alternaters ...Lucas, the prince of darkness.)
Seriously, How did the alternator accumulate that much corrosion?
After 14 years, mine still looks new. It seems like you have water coming in from somewhere.
Likes: BrianRobin
Well ... I'll have to track that down. I don't have a basis to compare to very many other installations.
I've been looking at the wiring, and wiring diagrams etc. online and it seems pretty straight forward. However there is no "G" terminal (For ground). There is an "E" terminal. I found one diagram that showed the E as another symbol for ground. Can anyone confirm that?
Sometimes, ground is referred to as Earth. So the E would likely stand for Earth/Ground. I believe this is a British term.
Sometimes the alternator uses the ground of the casing attached to the engine. The engine is grounded to the battery. So electrically it works. Not necessarily well but it works.
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
Okay maybe I ended up catching some of that Lucas smoke last Sunday. Now I know why you're looking at the alternator because that was the title of your first post!
Update: As those of you who said I'd better look for a source of water leaking onto the alternator said, there was a leak. Water was dripping on the alternator from the exhaust manifold and maybe risers. In any event I am quite a bit lighter in the hip area but have a water tight exhaust. It probably was leaking for some time, at least part of last season. The temperature never went over 160 and I was not suspicious of a problem until spring when I decided to trouble shoot a gauge which wasn't working.
Jul 5, 2011
754
Oday 28 Madison, CT
I say check all wiring. If, for example, the wiring near the battery connection has corroded to where it is 1/4" or less of its original gauge (i.e. strands broken), a lot of resistance and heat, maybe smoke also will result and it needs to be replaced.
Aug 3, 2012
2,542
That is a poster child for corrosion! Those wire connections have problems. The wires are probably corroded internally for an inch.
The whole thing looks wet!
So to wrap up, after a few weeks in the water with the new exhaust system the area under the engine is bone dry. Never has been before so I assume this had been going on for some time - like since I bought the boat.
Oct 17, 2011
2,809
Ericson 29 Southport..
Don’t let the smoke out! It is very expensive smoke and it has to be imported.
It’s also tough to get the smoke back in..
