Unplugged. Cause
1.device will enter a battery mode with lower consumption so that will lower the energy use.
2. You will have the benefit of the battery storage in the device. If you are plugged in you don't get to use those aHrs and instead rely on the aHrs of your boat.
Don't have any data on this so this is my opinion, and there is a saying about that.
Only if you never recharge the battery is it more energy efficient.
When you recharge you must put in more amp hours than you took out of the battery, batteries are not 100% devices, and efficiency decreases as charge level increases, a lead storage battery has 85% efficiency if only charged to 80%. that last 20% comes at a higher price. Charge efficiencies at 90% SOC and greater were measured at less than 50% in tests.
However, Lithium-Ion batteries are never trickle charged, the devices that use them regulate the charging so when they reach or approach full charge the charger cuts off and will not resume charge until the battery drops to some lower voltage, then charging resumes.
"Simple Guidelines for Charging Lithium-based Batteries
- A portable device should be turned off while charging. This allows the battery to reach the threshold voltage unhindered and reflects the correct saturation current responsible to terminate the charge. A parasitic load confuses the charger.
- Charge at a moderate temperature. Do not charge below freezing.
- Lithium-ion does not need to be fully charged; a partial charge is better.
- Chargers use different methods for “ready” indication. The light signal may not always indicate a full charge.
- Discontinue using charger and/or battery if the battery gets excessively warm.
- Before prolonged storage, apply some charge to bring the pack to about half charge.
- Over-discharged batteries can be “boosted” to life again. Discard pack if the voltage does not rise to a normal level within a minute while on boost. "
The charging efficiency of nickel metal hydride batteries is typically 66%, meaning that you must put 150 amp hours into the battery for every 100 amp hours you get out. The faster you charge the worse this gets. In a standby mode you might want to keep a nickel metal hydride battery topped up without damaging the battery. This can be done safely at a current of between 0.03 C and .05 C.
The answer is, we are hostage to the "Smarts" of the device charger, if it can power the device without overcharging the battery, leave it plugged in, if it doesn't, unplug it for use, turn it off for recharge. I don't know if anyone knows how smart a charger in a given device is.
The safest way is unplug during use, turn off during recharge, this however is not the lowest energy use from the boat battery side. On our boat since we have a solar panel, we tend to charge during the day, and unplug at night.
Don't take my word, Google it yourself, but don't rely on what you "think" it is, the answer may be more complicated, and for small devices the best energy efficient way is not worth the effort to achieve, as the gains are small overall.
