Ipad app for navigation
150
Hunter 41DS Reed Point Marina
Hi All:
What Ipad app do people use for gps and navigation software?
any free ones out there that are suitable
It is Ipad2 wifi
46
Hunter 35.5 Bayfield, WI
INavX. I don't use it as my primary nav aid, but if all else fails it could serve as a backup. It works well for planning routes. It does not meet your criteria of being free.
Jun 26, 2004
150
thanks.. I think i should have said reasonable instead of free.. I know you get what you pay for..Do these navigation apps come with charts?
Apr 11, 2010
969
Hunter 38 Whitehall MI
Inavx on iPad here too. Added an external gps and AIS antenna through a Digital Yachts wireless device. The 12 channel gps antenna greatly improves the accuracy
Easy to use, not free, but really not very expensive.
Nov 8, 2007
1,578
Navionics
Great back-up for my GPS, with seamless marina phoning on my iPhone.
My iPad does not have the GPS function, but the Navionics charts are really good on the iPad. I have the US/Canada Great Lakes package for regular use, and The Australia/Pacific package to plan the coming trip to Bay of Islands in New Zealand.
Sep 6, 2011
435
I don't use any for navigation but will use them for route planning and a back up to my plotter. I don't use anything for navigation except paper. I use nav aids on the iPad for marina info and the like.
Under $10 apps I like eseachart for its votive captain interface. I believe that included maps. (iNavx does his too). ISailor was free if memory serves and you buy maps. This app is good for planning.
If I can ever bring myself to spend $50 for an app I would buy iNavx. It looks great and review good. I. Just cheap and while I'll gamble $5 on an app to be what I want $50 is too much. I wish Apple had a policy giving you a few minutes (once) to try an app like he Android market had before I changed platforms.
It's on my list but I'm not a big gambler. SC
eliems
Apr 26, 2011
102
Hunter H28 Port Moody
iSailor and $9.99 for PNW Chart works great for me. I purchased the Bad Elf external GPS, ($99) for the Ipad and now I have Anchor Alarm as well as Navigation back-up to my Ray Marine system.
7
Hunter 45cc Oyster Bay, NY
I use Navionics express. Just completed the trip from new York to Florida and it was great as a backup and fantastic for planning ahead. Locating overnight spots with contact info made it easy. On the ocean at might was also very good. Of course it was secondary but a big plus.
Jan 7, 2011
5,456
Oday 322 East Chicago, IN
I use iSailgps on my iPad. I think it cost about $5 in the app store, and you can download NOAA charts for free.
Works reasonably well for my limited use.
I am attaching a screen shot of one of my day sails this summer. You can see our track (pink line). Where the line is broken, I turned off the nav software to take some photos and movies with the iPad.
I do find reading the iPad difficult in the bright sunlight however.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
I have Navionics on my phone and Ipad. I think the ipad version was $24.99 at the time I bought it. Works very well and seems very accurate (I have the 3g ipad which helps). The charts are free, you just download the areas you want. Although it takes a while to do that it's nice because your not using a lot of memory for charts you don't need.
Sep 6, 2011
435
deckboyscott said:
Anybody care to comment on viewability issues when tablets are used at the helm?
Fine under a Bimini but tough in bright sunlight. Glare reducing screen protectors help but not fix the direct sun issue.
I've pondered trying a Nook Color as well running an OS off the SD card. I suspect it will be the same. SC
Manny
Oct 5, 2006
983
Sailcruiser's right, it is okay under a bimini, but bright sunlight it is real tough. The nice thing is you could step into the companionway with it for a minute to get out of the light if needed.
Sep 6, 2011
435
Sailor, the iPad wifi doesn't have a GPS chip. You will need to purchase an external one for any navigation needs. There are several bad elf, dual xgps150 which is Bluetooth connected rather than plugged in. From there no I can't think of anything free but there are a few decent under $10 mentioned in the thread. SC
Apr 11, 2010
969
Sorry sailcruiser but the iPad does have an internal gps in it. It is a two channel receiver so it's accuracy is somewhat less than the traditional marine antenna which is a 12 channel receiver.
I have used the internal gps on my pad as well as the external antenna and they both work fine although in close quarters the accuracy of the 12 channel external is superior.
From Digital Yachts I bought a gps antenna and a AIS antenna and coupled them to the Digital Yacht dual channel wi fi unit so that they wirelessly connect and send NMEA data feed to the iPad. Use inavx navigation software and charts.
Very happy with the performance.
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
Do you have the G3 version of the IPad? According to the technical specifications from Apple, only the G3 version has A-GPS. Apparently, the GPS receiver is part of the G3 chipset on those machines. A rather long and lively discussion on this can be found over at the Apple Support Forum.
Cheers,
Brad
