Invest 99L --> TD 9 --> TS Ida --> Hurricane Ida
JamesG161
Feb 14, 2014
7,931
Hunter 430 Waveland, MS
Investigation 99L is a Tropical wave birthed in the Caribbean.
The Tropical Waves off Africa have been weak from low HEAT fuel.
The Caribbean has plenty of HEAT!
The Tracking models are still weak, but if it enters the Gulf of Mexico, land impact looks possible.
Saturday the 28th, models will tell the story and we probably see the Hurricane Hunters first flight into Invest 99L.
The LOW pressure front over Kansas today, will move East at ≈ 10 mph, and create the path of least resistance for Invest 99L to follow.
I know you get tired of us saying...
Prepare Now!
Jim...
PS: John and I are updating our boat preparation list, and will soon post it for other to contribute their ideas.
PSS: August 28th is the Anniversary of Hurricane Katrina land impact.
JamesG161
Feb 14, 2014
7,931
All the major models agree that Invest 99L will enter the Gulf of Mexico and have a USA land impact.
Likely to hit land as Hurricane Ida.
The storm appears to miss the disruptive land as it passes through the Yucatan Channel.
The Gulf Stream is providing the HEAT Fuel to quickly build the storm.
Hurricane Hunters will fly probably on Friday to provide the best information. After their mission, the Tracking models will be very close together.
Jim...
JamesG161
Feb 14, 2014
7,931
Tropical Depression 9 has had the first Hurricane Hunter Flight into the Storm.
It was a low level flight to find the circulation, which they did find.
No Dropsponde Buoy done.
My guess they are waiting for TD 9 going in to the Gulf of Mexico, Friday Morning, for the best Storm data.
So this is applause for them.
:clap::clap::clap::clap::clap:
Jim...
2,173
Hunter 40.5 Beaufort, SC
BOHICA Gulf Coast! Thanks Jim for the update and those in the path, be prepared and our thoughts and prayers are with you if the Gulf heat builds this into a big storm.
2,173
@JamesG161 I know you are probably busy getting ready for this storm so no need to respond. Just hoping that now you are back in the water (I think that is the case) everything works out favorably in riding this one out better. Be safe.
JamesG161
Feb 14, 2014
7,931
Update on Tropical Storm Ida...
Hurricane Hunters and NOAA aircraft are alternating storm passes.
Note MUCL which is an Airport showing West winds and 20 knts.
The HH flight notes Hurricane winds on the NE side.
Best tracking view so far...
I like this View from Mariners version from NowCoast.
This show the steering winds for the storm.
The Bad news is the HEAT- Fuel Source Path.
Right over the Gulf Stream Fuel depot as the HIGH pressure moves East at ≈10mph.:facepalm:
This shows the Gulf Stream currents.
When TS Ida enters the Gulf they can predict Eye wall land fall within 50 miles. My guess Sundown tonight.
Prepare now!!
BOAT PREPARATION IDEAS for Storms
Dammit Jim...
May 1, 2011
5,270
Pearson 37 Lusby MD
Just saw a forecast of category 4 (major) hurricane as Ida sucks energy out of the Gulf. Getting scary indeed! Stay safe.
JamesG161
Feb 14, 2014
7,931
Hurricane Ida has a well formed Eye, and is over Cuba now.
Major intensification expected, as it is HEAT fueled by the Gulf Stream, on it's project path. [See Graphic of Heat above]
The next Hurricane Hunter flight through, is the key one. They are on the Runway at Kessler Air Force Base [Biloxi] now.
Their flight will tell Locals Officials of Eye landfall within 50 miles.
Listen to Local Officials, since they have a direct connection with FEMA. [yes, FEMA has control]
All major models are showing the same landfall swath. No need for us to show the swath.
Now projected a Cat 4 landfall.
The EYE central pressure is projected to be 960 kPa or millibars.
[Note the lower the central pressure the higher the winds. Katrina was 828 kPa]
DAMMIT Jim...
JamesG161
Feb 14, 2014
7,931
Hurricane Ida is in the Gulf and is behaving as Forecast.
I am not going to do much more on this storm, but give you a few links to watch the Storm Surge. [NOAA definition]
These will be Wind, Pressure and Water Level
Station Home Page - NOAA Tides & Currents
Very close to Landfall point.;);)
This is on the East Side of storm, so it should be the highest Surge.
Thanks to all SBO friends for their kind thoughts and hopes for good luck.
We SBO Sailors that normally Contribute here and are within the Hurricane IDA path area...
@kloudie1 , @BigEasy stay in touch behind the scenes.
This is an average Storm Surge for us.
DAMMIT JIM....
IDA is still building. Land fall still expected somewhere just west of Grand Isle
15 mile eye has formed. Listing is a Category 4 Hurricane. Winds range from 130 to 156 mph.
Interesting Satellite photo this morning from Windy. Showing the eye of the storm. You can look down through the center and view the ocean.
Nov 6, 2006
10,150
I am trying to find the Hurricane Hunter data from the sondes .. The links disappeared from "spaghetti models" and I did some googling and can't find the mission reports. Where did they go, John?
Nov 6, 2006
10,150
Perfect ! Many Thanks..
Looks like 40-50 where my boat is right now.. I just got a note that the power is off at the slip..
