Circuits
Also try Xantrex they have their manuals posted online with wiring diagrams from the installation book. Do a google on statpower, too. I reemmber donloading the whole manual when I helped a friend put his in. If you can't find it, let me know and I'll email it to you.If you're putting in a separate inverter you MUST use a Blue Seas 8032 switch, or equivalent. It keeps the inverter power separate from the incoming AC so you can't ever use both at the same time.Re Patrick's suggestion: It would be relatively easy to switch the power back on if the Heart I/C charger fails (I have one), because I wired the AC through a terminal block, which simply means having to switch three wires. Sure, you could do it with a switch, but it would certainly have to be either well hidden, or well marked to avoid "the brother-in-law" syndrome heard many times about the 1-2-Both switches.
