Hardware
Anthony,Are you planning on racing with the spinnaker? If so, you really don't want to skimp on the setup as inadequate rigging can cost valuable time in setting and dropping the spinnaker. The rig needs to be sound even if just cruising.The jib halyard simply will not work! Spinnakers fly out front of the forestay and using the jib halyard would cross the stay causing chafe and potential wraps around the forestay. The spinnaker is normally set with the jib up, allowing you to get it hoisted and rigging adjusted before it fills completely. The jib is then lowered. When dousing the chute, the jib is first raised, again blocking and depowering the chute before dropping. It can be done without the jib by blanking the chute with the main during hoist and drop but this is very slow and inefficient and dicey in gusty winds. A separate halyard led from a block at the masthead bail in front of the forestay is a must! Mount an organizer (go triple!) on the port side by locating the mirror position from the halyard organizer on the starboard side. This will put you over the metal backing plate. I don't have a diagram of the exact location of the plate but its there on my boat! The best method is to drill and tap the holes for bolts. This requires the proper drill and tap tools and someone who knows how to do it. I didn't so I drilled and thru bolted mine using large oversized washers for the nuts inside the cabin. Again, it has worked fine with no problems for about 7 years of hard use.lines from the organizer (halyard, topping lift and need to be led aft through a triple stopper on the port side cabin top. Again, locate a mirror position from the double stopper on the starboard side used by the main and jib halyards. There is a metal backing plate so your choices again are drill and tap or thru-bolt. Locating an extra winch there is important as one person can then handle the halyard hoist, adjust the pole and trim the sail from that position. You don't have to have an expensive self tailer, just mount a cam cleat to use when using this winch to trim the sheet/guy. This is especially useful when sailing shorthanded. In light air, two of us can handle the spinnaker but normally need a minimum of three. Four is even better when racing to avoid too much multi-tasking! I simply used an 8' step ladder to mount a padeye on the front of the mast for the topping lift block. To avoid drilling into wiring inside the mast use a short drill bit and take it slow. I put a small cheek block at the base of the mast to lead the topping lift halyard to the triple organizer. Chafe isn't a problem. For the downhaul, I attached a small block to the metal base plate at the foot of the mast. It'd be better farther out on deck but I decided against drilling the holes for the padeye. I may do that soon as it would be better located out farther. I'm not aware of a metal backing underneath the deck in front of the mast but the glass is pretty thick in that area and thru-bolting with an interior backing plate should be fine.As for pole length, check your local racing rules if you're going to race. Many clubs limit pole length to the J, which is 10' for the 25.5. If no restriction or if not racing, a longer pole, about 12', will project the sail out farther but you can't do a dip pole jibe without detaching the pole from the mast but you can simply doing an end for end pole switch. The dip pole method is faster and easier but end for end works too. I would suggest looking at other rigs and, if possible, go sailing with someone with a spinnaker to see how it all goes together. There is also an excellent video, "Spinnaker Sailing", if you can find a copy. I think it may be out of production but I recommend it if you can find one. Flying the chute in a nice breeze is exhilirating and so much faster than even a large jib poled out or reaching! Its an exciting skill to acquire. I'm no expert but have been using mine for club racing for about 7 years now. There;s a couple pics of Honey Bear flying hers in the Boats Section under owner photos.Do you already have the spinnaker or are you shopping? I hope this is not too confusing!! I don't have any pictures of the rigging and hardware I can show you but if I can get some in the near future I'll send them to you.Dick
