Hi All,Since posting the article/blog on installing seacocks I've had a lot of emails and questions regarding the "mismatching" of different thread types such as NPS and NPT.Ross put me up to the challenge so last night I made a cut away view to show why using two different threads is really not such a good idea.I basically used a bronze nipple or threaded pipe with standard plumbing threads of NPT (National Pipe Tapered) and a bronze coupling also the industry standard of NPT thread. NPT threaded fittings are the thread pattern sold at all marine stores for things like elbows, valves, nipples, couplings and hose barbs.I cut the bronze coupling almost in half, for a cut away view, so I could thread the NPT bronze nipple into one side and an NPS through-hull fitting into the other. I then sprayed each with a McLube, to reduce friction but save the picture quality, and threaded both the NPT nipple and the NPS through hull into the cut-a-way bronze coupling, by hand, and until I had sufficient yet equal resistance on each. The results even surprised me! As you can clearly see the NPT nipple threaded into the NPT coupling a LOT further than did the NPS through-hull. If you were to take a wrench to both you might get one more turn at best out of the NPS through hull but you may get two or three full turns out of the NPT nipple. If you look very closely at the picture you can see that the outer threads of the through hull are already NOT fitting tightly against the female threads of the coupling and the inner few threads are quite tight or virtually bottomed out...!!! The square peg evidently does NOT fit a round hole..! This coupling represents the threads of an in-line valve. Most ALL ball valves or gate valves have NPT or tapered threads and most all through hulls have NPS or straight threads. We finally have a definitive answer, and photographic proof, and can clearly see from the photo how potentially dangerous it is to stick a ball valve directly onto a through hull.. Sticking a ball valve directly onto a through hull gives you about four or five threads between sinking and floating so I'd suggest just not doing it. It's probably best to use proper seacocks with flanges and the correct and matched threads..!!
