Installing Radar wiring on Hunter 356
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I have 2007 H-36 and no struts so my mast most likely different but going to boat today
and will check and I know I do have conduit inside my mast and saw them when top of mast.
I think the front but will look and are you doing with mast down I hope.
Have you tried contacting Selden.
Nick
Dec 19, 2006
5,832
Chuck ran a new cable so he should have good idea how the cable runs in the mast and my
Mast is newer with out struts.
My dealer installed the radar cable and I can see a bump in my headliner and it’s the radar cable
and some times it is seen more than other times.
Also running the cable up at helm goes up the stainless pipe on port side only and mine was full
of wires when I added a extra wire and used some kind of lub.
Nick
Mar 20, 2004
1,749
since the starboard pipe at the helm carries the throttle/shift cable I added a second pipe on the port side since my port pipe was also full.
the radar (if you're mounting on the mast) usually goes above the spreaders; the outlet for the conduit is on the front of the mast.
