Installing new aft portals
1
Oday 37 San Diego
I recently purchased an 1980 Oday 37 with 3 other family members. I need to replace the aft portals. any suggestions on brand and next place to purchase
Aug 2, 2005
1,155
Hello DAG Stew,
Check for a brand name on the ports or the frames. Might be Beckson. If they are Beckson just search Beckson Ports and buy from the company or check this site. Size information will include "glass" size (perhaps lite size), cut out size, and overall size (includes the frame). Gaskets, screens, "glass" are also available seperately if you only need parts. If you only buy parts remove the old ports and recaulk the frames anyway. Use care removing them and save the parts until the repair is complete.
Best Wishes
NOTE: I did edit my original post. I had written "Bomar" by mistake for the brand name.
976
Hunter 27 Pecan Grove, Oriental, NC
The PO replaced all of the opening ports on my Oday. I don't know what the originals were but the new ones are Becksons. See link: http://www.beckson.com/ports.html
For an inexpensive plastic port, they are well made and don't leak as long as you keep the gaskets clean.
Jan 10, 2011
13
Oday 32 T.C.
Stern portlights
I have a 32 oday 1978 and i bought mine from West Marine. If you go to their web site and follow the measuring instructions it is pretty easy. Also, I used Dap Bathroom chaulk and it worked out well.
Dec 14, 2009
63
Oday 37CC Norfolk, VA
They should be beckson 5x12's - the white frame/clear glass version is P/N BEC-PO512DWC20 (substitute the W for B for black frame, and C for S for smoked glass). Agree w/ Sailvayu - use a proper bedding material like boatlife, etc - for a few $ it's not worth risking any water incursion and ultimately delamination.
Nov 3, 2010
564
Oday 39 Lake mills WI
Another anti (DAP bathroom calk) vote. In fact you should not use Dow 795 or silicone for this job. That is for sealing a fixed port. One you can't open and you just mount the lens over the opening. Silicone will not attack the lens.
You are mounting complete units so the sealant will not come in contact with the lens. This is where boat life calk and other more aggressive goo's comes in. It's much tougher and aggressive and it's seal will be broken.
Simple rule: use silicone and only silicone in contact with any lens and stay out of home depot.
good luck
