Installing jib car tracks on the deck
10
Beneteau 423 Toronto
I have installed 2 winches on the cockpit coaming to create 4 winches vs the 2 winches on the deck top.
Now the angle of the jib sheets to the rear winches is incorrect. I have seen the offshore rig on a Hunter 33 with the second set of tracks on the deck. I would like to do the same but it requires going into the head liner to add backing plates and screw down the bolts.
Anyone done this?
Thanks
Geoff
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
A picture is worth a thousand words and makes it much easier to help with comments.
Jun 9, 2008
1,860
- -- -Bayfield
As mentioned, a pix helps, but you may have to run your sheets back to a couple of foot blocks (one on each side for each sheet) so that you get the proper lead to the winch (a foot block can be a cheek block or something similar to turn it at the back and lead the sheet forward).
