Do not rig your jib downhaul like this picture.
First: The connection should be to the second hank from top, not the top one/headboard. Why? Because connecting the downhaul to the top, next to the halyard will cause a foldover, jamming it up. The second or even third hank will include the luff in the downhaul action.... works perfectly.
Second: The downhaul line doesn't need to be interwoven around, or threaded through the hanks. A free line will minimize friction. Simply adjust its tension to pull out the slack.
Finally: Use small diameter line. My downhaul is 1/8" dacron.... There is very little load on this line.... it's purpose is to control the drop of the sail so you don't have to go forward to lower it. My routine is to hold the halyard in one hand, the downhaul in the other and steer with the tiller between my knees, allowing me to steer the boat under the sail as it comes down neatly on the foredeck. Cleating off the downhaul will keep the headsail under control as you proceed towards your destination.
