Injected epoxy resin into longitudinal stringers
2
Hunter 260 Beaver Lake Sailing Club
I am looking at a 1995 Vision 36 that has had the following work done.
1. Injected epoxy resin into longitudinal stringers. Survey said they were weak?
2. Removed mast - Dug out mast step - Installed new mast step - Glassed in place -
Installed mast.
Has anyone else experienced these type of repairs and are they common?
Thanks for your help,
Greg
Rick D
Jun 14, 2008
7,203
Greg, there are not that many, so I doubt you'd get replies. I had a V32. As long as I have been on this board; almost from the beginning, this is the only time I have ever heard of these issues. Having said that, the hull construction isn't any different from the several thousand Hunters built in the same era, and I have never heard of that either. To what did they attribute the cause?
Sep 28, 2009
2
Thanks Rick. They didn't say. Sounds like this boat has problems. The curent owner said it came up on a survey and the boat yard injected the resin in the stringers to make them stronger? Sounds like this boat has problems. It also had the past step redone. I also am going to look at a 1989 Vision 32. How did you like your V32?
