W
Are you aware you just "cemented" your transducer to the hull? Good luck when you need to replace it! RonI found the place on the hull where it got the best reading then just bedded it in epoxy. Just make sure there are no air bubbles. Works fine.
Your method represents non-standard practice and disregards manufacturers recommendations. Epoxy certainly duplicates the hull material and because of this bond requires drastic engineering to remove it and considerable time re-engineering the mess you've made once it's out. Contrawise, a 2 minute soaking in Antibond will release the most tenacious grip possible with 5200 and leave a reasonably clean surface that can be finished with a small scraper and some 80 grit sandpaper. In regards to your concern about transducer signals, most sailboats do not have the same need for accuracy as a nuclear sub. Depth and speed gauges are pieces of navigational information that need to be accurate but also are factored with other considerationsEpoxy is far easier to remove than 5200. I am a shipwright and have had to work extensively with both materials. In this application epoxy works best because it very closely duplicates the hull material and limits or eliminates any corruption of transducer signal.
