Inflatable Boat
Russ Garecht
Does anyone know of a good web site for honest reviews of inflatable boats and outboard motors? I am thinking of getting my wife a new inflatable and motor for Christmas. We will name it Pinky Ring Russ Her Diamond Ring
Dec 2, 1999
15,184
Practical Sailor is one source.
Russ: Practical Sailor seems to have inflatable reviews about every other year. This is a good place to start. They have also had reviews on outboard engines. Being that you live in Mexico, I would suggest that you find a good source of parts and make your determination based on being able to get that brand repaired and warrantied down there. As far as the inflatables go, you also need to consider warranty work. Make sure that you DO NOT purchase a PVC inflatable. They will not hold up in the sun in your part of the world. Hypalon is the only way to go. You also need to decide on how it is going to be used. The RIB units are really nice. They go fast and get up on a plane. The also can be beached without the worry of punctures. The down side is the weight and storage of the unit. There are some new ones with a single hull that make them much lighter but they still cannot be stored aboard the boat. If you go with a regular inflatable you need to decide on a rigid floor or an inflatable one. You really will not go wrong with Avon, Achilles, AB or Caribe. There are also some others that are very good too.
Tim Schaaf
Check Tucson
Russ, as you have probably found, none of the inflatables are serviced in San Carlos, or Guaymas. Tucson is your nearest spot, and I question whether any of the quality manufacturers are represented there, either. Of course, a good inflatable should need little service. Most repairs you can do yourself. San Diego is probably going to be your source. Most of the companies are represented there, and Downwind Marine could give you some good advice. To Steve's list, I would add Tinker and Apex. The later is a very well made inflatable from Costa Rica, I think, and is more boat for the money than some others. Having had extensive personal experience with Achilles, Avon, and Tinker, I personally would rate the Achilles as most trouble free (with the exception of one memorable model year) and best value, and the Tinker as most useful and fun, all around and most expensive. Avon is the old industry standard, and I have one right now with an inflatable floor, but it is no better than the other two, if as good. By the way Avon is now owned by Zodiac, although they claim there will be no bad consequences as a result....we will see...Zodiac has always been the hands down industry leader in ludicrous customer relations and phantom warranties. Good Luck. And get Hypalon!
