In modern age do people use their big water tank or go to bottled water, tank seems health risk? Removing front h26 tank would free up room. - D
Oct 8, 2023
116
Hunter 260 Kemah
We did cut the plastic thin water pipes underneath the sinks, and just put the pipes into 1 gallon water bottles from store to let us use the sink manual water pumps. . .
Oct 6, 2007
1,184
Hunter H30 1982 Chicago IL
I use the tank water for washing and dishes, but stick with bottled water for drinking & brushing my teeth just to be safe.
I always add roughly a tablespoon of chorine bleach when filling my 40 gallon tank and I keep it fresh by not skimping on my use of tank water. I pretty much follow Peggy’s recommissioning procedure every spring. Without the vinegar though. Just an extra fill and flush of the system.
Likes: Tally Ho
May 24, 2004
7,237
CC 30 South Florida
In modern age do people use their big 40+ gallon water tank up front or do they go to bottled water, tank seems health risk AND BOTTLED WATER HAS GOTTEN CHEAP AND COMMON unlike the 1980s? Removing front h26 tank would free up room. - D
Water tanks are OK if properly treated. Like most I do not devote much effort into treating the tank so I use bottled water for drinking and cooking, but to remove the water tank would be a mistake as water is needed for cleaning chores, as a cooling agent, showers and other uses. Last but not least it will diminish the sales value of the boat.
Aug 6, 2025
39
Sceptre 41 Vancouver
Jeesh.
Only in British Columbia's southern parts could one get bottled water. Our tap water is fine, and if you don't trust your tanks, empty them and clean them (see Peggy's post).
We use a "Rainfresh" (Canadian company) carbon and ceramic filter (under galley sink) when we are concerned. (FYI: Brita and PUR tap filters remove some chemicals and taste but NOT biological issues, such as giardia. Carbon/ceramic filters such as Rainfresh gets rid of taste, chemicals, protozoa such as giardia and some bacteria. But chemical such as chlorine - - or UV or boiling -- required to get rid of all bacteria and virusus. Chlorine not very effective for protozoa. Chlorine and good filter - - not Brita - - a good combination. )
But we NEVER use bottled water in BC, at home or on our boat. (We see a few buying it and wonder why.)
Likes: Timm R Oday25
Jun 1, 2009
1,881
Hunter 49 toronto
Jeesh.
For at the dock usage, install a dock water inlet. Massively worthwhile project
