Impeller Difference
90
Hunter 356 sandusky ohio
I'm about to change the impeller and I noticed some impellers have a plastic insert and some have a brass insert, of course the one's with the brass insert are three times as costly, are they worth it ?
Feb 10, 2004
4,247
Hunter 40.5 Warwick, RI
Are these engine raw water pump impellers or what? I've never seen an engine impeller with a plastic hub.
Dec 4, 2003
90
It's for the engine. WM has them in their catalog, the plastic are 30.00 and the brass are 80.00.
Feb 10, 2004
4,247
Well you got my curiosity. I looked in the 2011 WM catalog (later I have) and I did see impellers with plastic hubs. But I didn't see where there was a choice between the two materials for the same impeller size. It seemed like some styles are plastic and some are brass. Since the listing I saw was for Jabsco impellers, I presume that the plastic is not a cheapo substitute, but is the original design.
Am I correct?
Feb 10, 2004
4,247
If you look at the impeller profile page, the"G " style fits my boat.
I see three "G" impellers. Two of them are plastic and are the same size but different material. The other is brass but is a different size and type of drive.
Is your original impeller plastic?
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Torresen.com
First off $80.00 way too high and try calling Torresen marine for all your parts,pretty sure they in your area to sell to and just picked 2 impellers and O rings for $41.00 at my Yanmar supplier here in Florida and they need to be brass.
Nick
Nick
